I am going through the DC book and find the analogy with water flow a very good one, but there is one thing I find a little confusing:
I assumed that the poles of a battery are isolated from each other, because on the one side you will have a surplus of electrons and on the other side you will have a deficit, thus creating a voltage drop between the poles.
However, in section 1.4 (Voltage and Current), the water analogy goes on to say that there must be a continuous flow back to the reservoir, and there is an illustration of a pump pushing the water (which are the electrons in the analogy) back to the reservoir to form a closed loop.
This is confusing, as it seems to suggest that electrons must be flowing inside the battery as well, but I thought this not to be the case.
Please can you help to clarify this for me.
