Hello all,
If I understand it correctly, to convert single phase AC to DC using a rotary converter, AC is supplied to the rotor coils in a permanent field via slip rings causing the rotor to spin - like a conventional AC motor.
Then, this rotation causes electrically separate rotor coils to have a current induced in them as they are rotating in a permanent field, causing DC to be output via the commutator.
If this correct?
Are the rotor coils for the AC and DC sides indeed electrically separate?
Kind regards,
Aidan.
If this correct?
Kind regards,
Aidan.
