I built a relay circuit to control the direction of the motor and it works perfectly, however i purchased a PWM from amazon and when i attempt to hook up my circuit to the PWM it stops running.
The connection i'm attempting is i connect both relays to + and ground from the PWM connections and then i connect the M1 and M2 connection to the motor. Nothing will happen like this, i have tried different connections but still nothing has happened. What am i doing wrong?
This is the PWM: http://www.amazon.com/DROK-Controll..._2?ie=UTF8&qid=1429380980&sr=8-2&keywords=pwm
I have attached the schematic for the relay circuit.
