Are fanless Chromebooks OK?
Discussion in 'Computing and Networks' started by tjohnson, Aug 14, 2015.
  1. tjohnson
    Thread Starter Active Member
    Dec 23, 2014
    618
    122
    I'm planning on buying a Chromebook (specifically an Asus C201) for college, and was surprised that a lot of them (including the C201) don't have any cooling fans. Do you think this makes them prone to overheating, or should they run fairly cool even without them?
  2. strantor
    Oct 3, 2010
    4,302
    1,989
    I was issued a macbook from my last employer and, like you, was surprised to find it had no cooling fan. The macbook is a more powerful machine than a chromebook. A chromebook, as far as the specs I've checked, is just a tablet with physical keyboard. My android tablet has no cooling fan so i don't see why a chromebook would need one. Plus i suspect they wouldn't be selling them if they were prone to overheating, and if they did, it would be very evident in the reviews.
    The deletion of a cooling fan means reduction of power consumption (and heat)
    tjohnson likes this.
  3. shteii01
    Feb 19, 2010
    3,515
    515
    The way I understand it, chromebooks do most computing at the remote site, so the actual chromebook does not do much computing and does not need powerful cpu, which means there is very little heat, which means there is no need for fan.
  4. DickCappels
    Aug 21, 2008
    2,777
    674
    Any respectable company will go to great lengths to assure that their products will be reliable in the field. Some of them fail at the attempt. I would not worry as long as the manufacturer has a good reputation for reliability and the ability to resolve problems quickly.
  5. tjohnson
    Dec 23, 2014
    618
    122
    I agree. I was also starting to think that if Android phones don't need fans, tablets and netbooks likely wouldn't either.
    Which means longer battery life. Me thinks I shall like a Chromebook very much.:)
    I know that Chrome OS apps are web-based, but I don't think loading webpages on a Chromebook does any less computing than loading them in Chrome on a PC.
  6. Brownout
    Jan 10, 2012
    2,375
    998
    They are perfectly safe. The fanless operation is due to the energy efficient design. I use a chromebox running Linux, apps run locally. No overheating issues.
  7. atferrari
    Jan 6, 2004
    2,670
    785
    My ZX81 was also fanless and worked OK
  8. tjohnson
    Dec 23, 2014
    618
    122
    My Chromebook was delivered today and I'm posting from it right now. So far setting it up and learning how to use it has been pretty painless. Thanks to everyone for their helpful input.
  9. strantor
    Oct 3, 2010
    4,302
    1,989
    What? I can't read your post. I think something is wrong with your computer.
  10. tjohnson
    Dec 23, 2014
    618
    122
    I don't understand.o_O My post was written in English, your quote is exactly the same as what I originally wrote, and my computer (which I'm posting from now) is working fine.
  11. strantor
    Oct 3, 2010
    4,302
    1,989
  12. tjohnson
    Dec 23, 2014
    618
    122
    I came across this video and thought it was funny:
