Are bidirectional cmos to ttl ICs ??
Discussion in 'General Electronics Chat' started by mohammad2050, Nov 16, 2014.
  1. mohammad2050
    Nov 14, 2014
    56
    i have a question about cmos to ttl ICs (for example SN74HC244) . Are bidirectional this ICs ??
  2. RichardO
    May 4, 2013
    1,342
    431
    The SN74HC244 is not bidirectional. For that you would need a SN74HC245 or equivalent. The SN74HC244 and the like are not really intended to convert between CMOS and TTL levels. They are usually used in a circuit that is powered by a single 5 volt power supply. Does this answer all of your questions?
  3. mohammad2050
    Nov 14, 2014
    56
    yes
    thank you
