Read the link mcgyvr provided above, that tells you...which pin is the digital input.
It is hard work and requires much beer.as always... Step #1 = Read datasheet
It will eventually come back and bite you, if you don't read datasheetIt is hard work and requires much beer.
If you want any help you are going to need to provide more information..hi,
i connecte the dac 0800(8bits) with arduino uno but it does not work
i make a digitale variable voltage(0 to 255) in the inpout of the dac, but it gives me anything in output.
the circuit is in figure 1 in the datasheet.
please help me.
Again, you must read the datasheet. How can you expect to use a piece of hardware you obviously know nothing about? Answer: read the datasheet.hi,
please help me.
