Hi!
Using the Arduino UNO, I want to power it from a battery, so I watched a tutorial and plugged in the 9V battery to the VIN pin and to ground.
The Arduino has a recommended input voltage of 7-12 V, as the documentation says. When I did this, the Arduino got much more hot than it is with 5V from a USB cable. It's not melting, and I can keep my finger on it without the need to remove my finger, but it's still hot.
- What temperature is dangerous for the Arduino? (Maybe I'm overreacting on the heat)
- How can I use a 9V powersource and get 5V to my components?
- SHOULD I even use a 9V power supply?
