Arduino Uno command an optotriacs in a bridge rectifier
Discussion in 'General Electronics Chat' started by Cristian Sae, Mar 21, 2016.
  1. Cristian Sae
    Mar 21, 2016
    I need to know if i can use optotriacs instead of thyristor in the construction of a bridge rectifier which i is commended with an Arduino UNO. I really need help . Thank you!!!
  2. crutschow
    Mar 14, 2008
    13,505
    3,376
    I would think you could, but we need more info.
    What is the purpose of using the Triacs in the bridge?
    Are you trying to regulate the output voltage using phase control of the Triacs?
  3. Cristian Sae
    Mar 21, 2016
    yes i am trying to regulate the output voltage using phase control of the Triacs. i must test this for my licence project.
  4. mcasale
    Member
    Jul 18, 2011
    210
    12
    Interesting project. If you are switching the triacs at various points in the AC waveform, I would think you'll be generating a lot of high frequency noise - both on the primary side, and possibly radiated too.
    Can you post a schematic?
  5. Cristian Sae
    Mar 21, 2016
    can you tell me if optotriacs can be comannded with arduino? i dont have a schematic . i want to learn if is posible to make a make a rectifier bridge with optotriacs. and after to control with arduino
  6. Cristian Sae
    Mar 21, 2016
    First part of the project will be a circuit of zerocrrosing used to know when arduino will command the bridge rectifier
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    You could use the MOC301X/MOC302X for opto triac.
    As said, you can calculate the needed delay from a zerocrossing.
    The MCU can only do this when you give it the zerocrossing info.
    Bertus
  8. mcasale
    Member
    Jul 18, 2011
    210
    12
    Yes, of course anything is possible, but it depends upon your requirements.
    For example, if you turn on the triacs at zero-crossing (recommended) then that dictates that your control of the output voltage is only 120Hz (or 100 Hz if in UK). That means that you can only react to load changes at that speed. Therefore, you will need a big filter capacitor. That's why switching power supplies today run at high frequencies.
    Can you put together a list of requirements and the kinds of load transients you expect? Then you can do the schematic.
  9. MrSoftware
    Oct 29, 2013
    545
    133
    One word of warning; we used an arduino to control a servo and the servo would hunt a little bit when it should have been perfectly still. The arduino wasn't sending a constant data frame rate to the servo. I'm not sure if the clock wasn't stable, or if there were some interrupts or other processing interrupting it enough to cause the varying output, but this is something to keep in mind if you need your output to be perfectly timed.
