Arduino uno board crystal
Discussion in 'General Electronics Chat' started by mrel, Jul 18, 2013.
  1. mrel
    Thread Starter Active Member
    Jan 20, 2009
    98
    Hello
    On the Arduino uno board there is 16 mhz crystal.
    Does anyone know if this 16 mhz crystal is it SERIES type crystal or is it 16 mhz crystal a 18 PF or 20PF crystal?
    Thank for the help mrel
  2. Ωhm
    Feb 1, 2012
    24
    mrel,
    You need 2 ceramic 22pF load capacitors in parallel if you use an external crystal. This picture shows it nicely. If you use a ceramic resonator instead of a crystal, you don't need the load capacitors.
    Ωhm
  3. mrel
    Jan 20, 2009
    98
    The thread i post about the crystal,what i trying to find out is what kind of crystal on the arduino uno broad I know it a 16mhz crystal But is it a(series type) or (18pf type) or (20pf type).
    Because went to Digikeys website to buy crystal.
    Digikeys lists three different type crystals there are series,18pf,20pf.
    So question is what kind of crystal on the arduino uno broad (series ,18 pf,20pf ).
    mrel
  4. panic mode
    Oct 10, 2011
    1,328
    305
  5. panic mode
    Oct 10, 2011
    1,328
    305
