Arduino Shields?
Discussion in 'Embedded Systems and Microcontrollers' started by spinnaker, Dec 29, 2015.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,065
    1,163
  2. djsfantasi
    Apr 11, 2010
    2,900
    874
    Re: Question 2
    Yes, there are wireless Ethernet shields. Click to see one.
    When using multiple shields, make sure there aren't any pin conflicts. I2C and other interfaces usually have unique addresses. Also, depending on which Arduino you are using, check that it supports the shields you are considering. Some require modifications to work. For example, there are specific mods on a MP3 shield and a Mega.
  3. OBW0549
    Mar 2, 2015
    1,389
    932
    Adafruit sells several Wifi shields for the Arduino.
  4. spinnaker
    Oct 29, 2009
    5,065
    1,163
    So does that mean it depends on if they are stackable?
    How would you know if there is a conflict? Will the list the peripherals it uses?
    What about binary in / out lines? Assuming the Arduino has such an animal.
  5. spinnaker
    Oct 29, 2009
    5,065
    1,163
    My other question is, will the ethernet connection act like a com port to the PC much like the USB port does?
  6. djsfantasi
    Apr 11, 2010
    2,900
    874
    Re: Question 1
    It is likely stackable. Make sure that all intervening shields have stackable headers. Since most shields package the headers separately, for you to solder, you can always buy stackable headers if your shield doesn't come with them.
  7. DNA Robotics
    Member
    Jun 13, 2014
    132
    33
  8. sailorjoe
    Member
    Jun 4, 2013
    361
    63
    This site maintains information for most of the Arduino shields, and allows you to check for pin conflicts. Find your distributor/manufacturer, find the board you want, and check the drawing on the pins it uses.
    http://shieldlist.org
  9. spinnaker
    Oct 29, 2009
    5,065
    1,163
    No one yet answered by question if ehternet connection on Arduino acts a a terminal (serial port). Anyone know?
  10. panic mode
    Oct 10, 2011
    1,328
    305
  11. djsfantasi
    Apr 11, 2010
    2,900
    874
    That is the internal connection between the Arduino and the shield. Ethernet communications are handled through the associated library. The functions provided in the library may act like a terminal. I am inspecific because your description of the communication as a terminal is vague to me.
    The library for that shield is documented here. When researching an Arduino shield, I make sure I understand the library first. Each product description usually contains a link to the library documentation.
  12. spinnaker
    Oct 29, 2009
    5,065
    1,163
    What I need to know is can I see it as a comport on my pc so I can connect instead of using the USB connection. I want it to be wireless from my PC.
  13. OBW0549
    Mar 2, 2015
    1,389
    932
    I'm no comms expert, but I believe the answer is "no." It would be a TCP/IP connection, not a COM port or equivalent.
    If what you want is effectively a "wireless COM port" then you might consider a couple of XBee modules to create a serial link, or possibly Bluetooth LE.
    https://www.adafruit.com/products/964
    https://www.adafruit.com/products/2479
