Arduino / Raspberry Pi
Discussion in 'General Electronics Chat' started by Lineout, Dec 1, 2013.
  1. Lineout
    Nov 20, 2013
    64
    What are the + and - 's of these two platforms.
    Which do you recommed for applications that you are familiar with?
    Personally , I eventually would like to be able to control rc cars planes via remote pc or android over the internet.
    I understand the languages are not the same +- , and one costs more....that's about all I know so far.
    What are your projects (ones you've completed , currently in) ?
  2. mcgyvr
    Oct 15, 2009
    4,787
    973
  3. MrChips
    Oct 2, 2009
    12,624
    3,451
    I would not attempt to compare Arduino with Raspberry Pi. There is a world of difference between the two.
    For RC, especially planes, quadcopters or drones, I would use neither. Too heavy.
    If you are now starting out learning about microcontrollers, get the Arduino and learn the ropes.
    For RC, I would roll my own using light weight ultra low power chips.
  4. Shagas
    May 13, 2013
    802
    74
    What would be the point of using ultra low power chips when the power taken up by a micro is going to be << 1% of the energy taken up by the power electronics eg. propulsion etc?
  5. Alec_t
    Sep 17, 2013
    5,967
    1,135
    Real-time control would be next to impossible because of the unpredictable signal propagation delays over the Internet :(.
  6. schitale
    Dec 27, 2013
    I am working on Raspberry Pi - B. I have to connect it to a AC Servo Motor Yaskawa 10C3C11.
    I will have the following connections:
    Rasp Pi ---- DC to DC booster ( 5 volts to 12 volts) ------ DC to AC inverter (12 volts DC to 110 Volts AC) ---- AC Servo motor.
    I have to order the Booster and Inverter, what speifications would be important?
    http://www.galco.com/buy/Yaskawa/sgmcs-10c3c11 (Motor Specifications)
    PS: I am sending PWM control signal from Pi to Motor
  7. Alec_t
    Sep 17, 2013
    5,967
    1,135
    Schitale, you have hijacked someone else's thread.
  8. GopherT
    Nov 23, 2012
    6,303
    4,021
    Internet delays aren't so bad, it depends on the definition of "control". If the unit is semi-autonomous, then the impact of delays are greatly mitigated. The Mars Rovers have substantial propagation delays, as do the drones in the news.
  9. Alec_t
    Sep 17, 2013
    5,967
    1,135
    Are they really controlled via the internet? I would have thought military comms channels, with predictable propagation delays, would be used.
  10. GopherT
    Nov 23, 2012
    6,303
    4,021
    No, I mean that the Internet delays can't be any slower than sending a signal to Mars (minutes of delay) or that semi-autonomous allows a sort of fail-safe in case there are propagation delays on drones.
