Arduino pulsing output
Discussion in 'Embedded Systems and Microcontrollers' started by Alasttt, May 13, 2015.
  1. Alasttt
    May 13, 2015
    68
    Hi all,
    I want to get a square wave that goes between +2v and -2v. From the arduino outputing HIGH then LOW gives a square wave between 0v and 5v. Any ideas on how I could change the arduino configuration to output different voltages for high and low. or alternatively how to use electronics to convert the 0-5 into -2 to +2
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Sure -- run your [0-5V] signal into a summing amplifier with a constant input of -2.5 volts and a gain of 0.8
    (0 - 2.5)*0.8 = -2.00
    (5 - 2.5)*0.8 = +2.00
  3. Alasttt
    May 13, 2015
    68
    Hi thanks. I have also heard putting a capacitor after it will AC couple it and have the same affect to make it +2 to -2. Would you agree ?. Since this might be easier then a summing amp.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    No. A series, or DC blocking, capacitor will change the square wave into a series of sharp impulses with exponential decay. Not what you are looking for.
  5. Alasttt
    May 13, 2015
    68
    Right ok thanks. Please could you tell me where could I get the constant input of 2.5v from ?.
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    A voltage divider.
  7. Alasttt
    May 13, 2015
    68
    Right thanks. Youve specified gain to be 0.8. Gain is Rf/Rin.
    So for the op amp, I connect the - input to +2.5v. connect the + input to the 0-5v square wave via a 10 ohm resistor, and make Rf 8 ohms.
    This gives 8/10 which is a gain of 0.8.
    Correct?
  8. MikeML
    Oct 2, 2009
    5,451
    1,066
    The best you can do without an opamp. If you use an opamp, remember that you will need a negative power supply, like -5V 211.gif
  9. Alasttt
    May 13, 2015
    68
    Thanks. Do you know if thers a way of changing the arduinos internal ADC voltage reference ?
  10. MikeML
    Oct 2, 2009
    5,451
    1,066
    To what end?
    Download and study the ATmega chip data sheet. I'm sure it can be done, but not likely through the Arduino supplied library.
  11. Potato Pudding
    Jun 11, 2010
    684
    92
    What he said.
    http://forum.allaboutcircuits.com/gallery/photos/a-summing-amplifier.2957/
