Arduino LCD Menu
Discussion in 'General Electronics Chat' started by gremlin, Feb 7, 2011.
  1. gremlin
    Jul 22, 2010
    19
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Have a look at the arduino websites tutorial on the display.
    You can wire it up as they have shown in the diagram. You will need to use an LCD that is based on the HD44780 controller.
    You will need to load the 4bit LCD library per the instructions.
    Using the library, you will find it very straightforward to use the function calls provided in the library.
    hgmjr
  3. gremlin
    Jul 22, 2010
    19
    yes had a look at that but want to select between a few screens with some imput fields with a button or pot ?
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    I believe you will find the LCD4bit library will be more than up to the performance you seek including the multiple screens.
    hgmjr
  5. gremlin
    Jul 22, 2010
    19
    thanks do you know of any exaples i can have a look at the code
    regards
    gremlin
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    Actually there is a "Hello World" example already available in the Arduino-0022 version that is currently available for download.
    hgmjr
