Quick Answer: YesHi,
To get an Arduino out on the internet https port 80 has to be open on the network right? I'm trying to get two temp sensors up on plotly
Any help would be awesome!
Also just realized you said https port 80. https is port 443 not port 80.Hi,
Network Settings
The shield must be assigned a MAC address and a fixed IP address using the Ethernet.begin() function. A MAC address is a globally unique identifier for a particular device. Current Ethernet shields come with a sticker indicating the MAC address you should use with them. For older shields without a dedicated MAC address, inventing a random one should work, but don't use the same one for multiple boards. Valid IP addresses depend on the configuration of your network. It is possible to use DHCP to dynamically assign an IP to the shield. Optionally, you can also specify a network gateway and subnet.
by Duane Benson
by Jake Hertz
by Jerry Twomey
by Aaron Carman
