Arduino dht11 and lcd display
Discussion in 'The Projects Forum' started by The Luminator, Mar 30, 2016.
  1. The Luminator
    Mar 24, 2016
    I'm simply trying to get an output instruction to run using the parameters of inside humidity inside temperature and outside temperature can I assign instructions to each internal reading on the dht11? Or do I have to use a third temperature sensor since the dht11on already on a breakout board with only 3 pins? This coding thing isn't my forte'.
    I've found several renditions of the Arduino dht11 library as well. Maybe one of an older format would work better. I see where there used to be source code for calculating a third value so I'm assuming there is a way, I'm just not aware. Someone please help.
