Arduino Connection
Discussion in 'Embedded Systems and Microcontrollers' started by MrYu, Jan 24, 2013.
  1. MrYu
    Sep 26, 2011
    42
    How's the pin connection between arduino and GSMSim900D? and view the activity using hyperterminal? thanks:)
  2. kubeek
    Sep 20, 2005
    4,687
    805
    Connect rx to tx and tx to rx? Check that they run on the same voltage?
    MrYu likes this.
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    What protocol/bus does the GSM communicate to the Arduino with? UART? I2C? SPI?
    The answer is a Bus Pirate, though I'm not entirely sure what your question is. :)
    MrYu likes this.
  4. MrYu
    Sep 26, 2011
    42
    i connect the rx-tx of arduino to the, tx-rx of RS232 to ttl converter. just want to test At-commands
    how i am gonna connect the GSM? tnx
  5. MrYu
    Sep 26, 2011
    42
    up............................
  6. kubeek
    Sep 20, 2005
    4,687
    805
    I am not sure what you expect, but most people here don´t read other´s minds and don´t have other superhuman abilites. I have no idea what that GSMSim900D is or how it is connected. So unless you post a datsheet and a diagram of how you want to connect it you will get very little good responses. And bumping the thread won´t get you much help either.
  7. tshuck
    Oct 18, 2012
    3,531
    675
    This thread is bothering me to continue seeing since the OP wants answers with minimal information, as such, I will jump in here...
    OP, is this the device datasheet?
    So, are you trying to communicate with the GSM module through UART, or SPI? You mentioned UART connections, from the Arduino to the computer, so you'll either have to do a software UART, or use the SPI interface...
    Draw a schematic to help the people trying to help you.
  8. MrYu
    Sep 26, 2011
    42
    Sorry for the lack of information.
    this is the GSM SIM900D module
    and this the arduino clone i am using
    since there is only one tx-rx pin in arduino and also in the GSM module,. how can i interface the RS232 to ttl converter?
    or anyone of you try doing that without bricking one of the device? tnx
  9. kubeek
    Sep 20, 2005
    4,687
    805
    And those DTR, DCD, RTS and CTS pins are there just for fun? If the modem needs them to communicate then you will have to connect those as well. But I have a feeling that you need to put your own program inside the modem, so I guess that is up to you.
    Also, why do you need RS232-to ttl converter when both arduino and the modem use TTL levels? (one could be 5V and the other 3.3V though)
  10. tshuck
    Oct 18, 2012
    3,531
    675
    How about answering some questions?
