Arduino code help.
Discussion in 'Programmer's Corner' started by c.marsh, May 22, 2013.
  1. c.marsh
    Thread Starter Active Member
    May 16, 2009
    100
    okay so im struggling with something.
    I'm trying to make a larson scanner with the arduino, the problem is i CANNOT use the delay function. I can make the scanner with it, but it locks out the cpu and i need some other functions running which wont work because of the delay.
    so using this example
    Code ( (Unknown Language)):
    1. const int ledPin =  13;      // the number of the LED pin
    2.
    3. // Variables will change:
    4. int ledState = LOW;             // ledState used to set the LED
    5. long previousMillis = 0;        // will store last time LED was updated
    6.
    7. // the follow variables is a long because the time, measured in miliseconds,
    8. // will quickly become a bigger number than can be stored in an int.
    9. long interval = 1000;           // interval at which to blink (milliseconds)
    10.
    11. void setup() {
    12.   // set the digital pin as output:
    13.
    14.   pinMode(ledPin, OUTPUT);
    15. }
    16.
    17. void loop()
    18. {
    19.   // here is where you'd put code that needs to be running all the time.
    20.
    21.   // check to see if it's time to blink the LED; that is, if the
    22.   // difference between the current time and last time you blinked
    23.   // the LED is bigger than the interval at which you want to
    24.   // blink the LED.
    25.   unsigned long currentMillis = millis();
    26.
    27.   if(currentMillis - previousMillis > interval) {
    28.     // save the last time you blinked the LED
    29.     previousMillis = currentMillis;
    30.
    31.     // if the LED is off turn it on and vice-versa:
    32.     if (ledState == LOW)
    33.       ledState = HIGH;
    34.     else
    35.       ledState = LOW;
    36.
    37.     // set the LED with the ledState of the variable:
    38.     digitalWrite(ledPin, ledState);
    39.   }
    40. }
    and the code i already have which is minimal:
    1. int pinled1 = 13;
    2. int pinled2 = 12;
    3. int pinled3 = 11;
    4. int pinled4 = 10;
    5. int pinled5 = 9;
    6. int pinled6 = 8;
    7. int pinled7 = 7;
    8.
    9. void setup() {
    10.    pinMode(pinled1, OUTPUT);
    11.    pinMode(pinled2, OUTPUT);
    12.    pinMode(pinled3, OUTPUT);
    13.    pinMode(pinled4, OUTPUT);
    14.    pinMode(pinled5, OUTPUT);
    15.    pinMode(pinled6, OUTPUT);
    16.    }
    17.
    18. void loop()
    19. {
    20. }
    I simply cannot work out how to get the scanner to do what i want it to. which this:
    led 1 comes on > led 2 comes on> led 1 turns off and led 3 turns on > led 2 turns of and led 4 turns on
    with a time of 50ms between the functions (but led 1 turning off at same time as led 3 turning on)
    can someone help me out by getting the first 3 led's working? after that i can type up the rest of the code as it turns out i can understand the code if i can type it out copying something that already works. bazaare i know but hey we all learn in different ways.
    I'm trying to keep each led's function seperated out so that i can add in other code along the way and get other functions running in the right places.
