Arduino Boards
Discussion in 'The Projects Forum' started by jismagic, Jun 2, 2014.
  1. jismagic
    Sep 7, 2013
    77
    I m starting a project with Arduino board. I am expecting the board to continuously run for 3 months.
    Do you think board can stand that long.
    I dont see any reason why it should not. Just want to get it confirmed
    thanks
    jis
  2. tshuck
    Oct 18, 2012
    3,531
    675
    Yes, they will let much longer, even. Make sure you spec your hardware correctly and (possibly) build some fault tolerance into your application and you should be fine...
  3. sirch2
    Jan 21, 2013
    1,008
    351
    Depends on environmental conditions (wet/dry/hot/cold) and handling but I've got Arduino boards I use for prototyping that a few years old and still going strong even though I take no care of them at all, they are just bare boards and get thrown in a box and then dragged out again, hooked up, programmed, use for a while and then back in the box, which is probably a lot worse than running them continuously.
    absf likes this.
  4. Fibonacci
    May 23, 2014
    25
    5
    From the Atmega 382 manufacturer, the data retention is 20 years at 85ºC and 100 years at 25ºC! There is no problem, only check your hardware.
    absf likes this.
