Sounds like you are describing a multi-pitch or multi-start screw where there are two or more threads running together on a single axis similar to what a DNA double Helix looks like.if you can imagine a solid or hollow piece of tube say 50mm in diameter and say 600mm long with a 10mm hollow plastic pipe fixed at the bottom end of the large tube at 45 degrees to the length and then wound at equal distance all the way up as a spiral (there are similar ones shown on youtube) tilt the large tube at 45 degrees and turn in a direction so as the bottom of the small tube scoops up water from a basin and eventually brings the water up the tube to the top and it pours out. my thought is this .if the large tube is 50mm in diameter and one small pipe is 10mm in diameter then if four more 10mm tubes were added side by side copying the same spiral fashion then I assume five times more water would be picked up and ejected at the top with the same revolutions ?
