ah.. you want a professional DIY project but know nothing about the numerous/vast subjects involved in what a laymen would deem "just a circuit board with leds attached to it"
Making the circuit board is the simple part (NOT cheap though for a 1-off DIY thermal clad).. Ensuring proper heat dissipation in the PCB/LED is tougher. Getting it produced at a reasonable price to make it even worthwhile is the hardest part.
Start here to get a basic understanding of heatsinks/heat dissipation/thermal resistances
http://sound.westhost.com/heatsinks.htm
Then you've got SMT soldering (stencils/placement/reflow oven) process and equipment involved.
Then design your schematic which will include a constant current driver IC
Then learn a PCB package to do the design/layout.
Then find a fabrication house to build your PCB and even take care of the assembly.
Then realize your wallet is now a few thousand dollars lighter.
Then go back to star mounted LED's like everyone else uses to DIY.
See where I'm going here..
