Apt Fire Pics
Discussion in 'Off-Topic' started by maxpower097, Jan 6, 2011.
  1. maxpower097
    Feb 20, 2009
    795
    388
  2. R!f@@
    Apr 2, 2009
    8,786
    771
    Why do you guys use wood to build houses. I have noticed this.
    We newer use wood to build houses. Not even in rural areas.
    But else where in the world people build using wood.
  3. spinnaker
    Oct 29, 2009
    5,065
    1,167
    Actually we use mainly plastic these days. :)
    Seriously wood is very abundant in the United States plus it is renewable.
    In the old days homes were made out of sod and buffalo chips were used for fuel. in the plains states , because that is what they had.
  4. R!f@@
    Apr 2, 2009
    8,786
    771
    We never use wood for the walls. It's always cement and bricks.
    We would use wood as the floor deck at times
  5. spinnaker
    Oct 29, 2009
    5,065
    1,167
    You have a lot of sand! :)
    Most homes is Porto Rico and Virgin Islands are cement (the good ones :)).
    Our floors are usually carpeted. I hate it. I put composite wood (looks real somewhat) on my first floor. I just need a broom to clean the floor and a mop once in a while.
    I would rather have a ceramic floor but that is much harder to put down if you do not have one already (our base floor is plywood). More expensive or older homes have hardwood. My parents have an old home and they carpeted over them!
    My friend in Italy lives in an all concrete apartment. It is like a bank vault. He has a steel door with big bolts that extend on 2 sides of the door when the door is locked. A third side has fixed bolts.
    Most homes there are stone or concrete with ceramic floors.
    In the U.S. you don't need to break in through the door or a window. A good razor knife will do. Cut through the plastic siding, the outside fiberboard wall (if there is one), pull out some insulation, cut through the wall board and you are in the house!
    Some homes in the US are brick. My parents live in a brick home. It is like a fort!. These are usually old or very expensive homes.
  6. maxpower097
    Feb 20, 2009
    795
    388
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    In Texas homes do not have cellars, though given we are in tornado alley we could use them. The reason is our bedrock is less than 6 feet down. It is hard to cut through bedrock.
  8. R!f@@
    Apr 2, 2009
    8,786
    771
    We can dig down to sea level :D
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    That's not a cellar, that is a swimming pool.
  10. Kermit2
    Feb 5, 2010
    3,847
    963
    It may be easy to break in to a house in Texas, but what is harder to do is not be seen by a neighbor while you are doing it.
    On my block, at least, we have a watch program and people who patrol the streets, not cops, people who live there.
    In Texas you can shoot someone who breaks into a neighbors home, and at night you can shoot them if they are merely on your property uninvited.
    We don't have a lot of home invasions in this state for some reason.
    Hmmm.
  11. maxpower097
    Feb 20, 2009
    795
    388
  12. maxpower097
    Feb 20, 2009
    795
    388
  13. gerty
    Aug 30, 2007
    1,154
    304
    If you are a felon in one state, you're a felon in all states.
    either someone is feeding you a line of bull, or someone down there isn't doing their job.
    It is against federal for a convicted felon to be in the presence of a firearm.
    That means not only can they not own/carry one, they cannot be around one.
    You might want to check the source of your facts..
  14. retched
    Dec 5, 2009
    5,201
    313
    Where are the pics?
  15. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Possibly the least pictury picture thread since happyganl's post your picture thread.
  16. retched
    Dec 5, 2009
    5,201
    313
    HA!
    Ain't that the truth!
  17. maxpower097
    Feb 20, 2009
    795
    388
  18. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Where's the fire pictures? Hell I'd settle for macaroni pictures.
  19. Robin Mitchell
    Oct 25, 2009
    738
    206
    in the UK, we have brick and solid stone!!!
  20. gerty
    Aug 30, 2007
    1,154
    304
    Like I said...
    Federal law still prohibits a felon from possesing a firearm. Someone in
    FL, giving out permits, does not make the felon exempt from prosecution for possesing a firearm.
    What is the "Felony Guide" you quoted from?
