recklessrog
- Joined May 23, 2013
- 985
The 21844 is an excellent driver chip, programmable dead time! but look at how the load is connected in comparison to the original idea. I have used this in several designs, also the SG 3525 has many desirable features and works well in an inverter I built that drives four 80 amp mosfets at 25khz . The inverter is used to generate 15kv to charge two 60mfd capacitors in series. Bear in mind that they represent a short on start up and the inverter has no problem with that!
