Applying a data bus in real life
Discussion in 'Computing and Networks' started by Sparky49, Jun 21, 2012.
  1. Sparky49
    Jul 16, 2011
    835
    417
    Hi all.
    Looking at some schematics, I see they have data buses. How are these implemented in real life?
    Are they just a bunch of wires/traces which run along side each other, as in my diagram?
    Many thanks,
    Sparky
  2. wmodavis
    Oct 23, 2010
    737
    150
    Just like any other wire connection line on a schematic. It is an electrical connection using a conducting medium such as wire or a foil trace on a PCB which joins two or more components. Yup! In Real Life! No rocket science to it. The epitomy of simplicity.
    Sparky49 likes this.
  3. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    you would not want to have all the wires in the schematic...
  4. Sparky49
    Jul 16, 2011
    835
    417
    Much neater indeed. So it's just a case of match up the pins? PS1 goes to P$1, in that case?
  5. cork_ie
    Member
    Oct 8, 2011
    348
    58
    Yep a databus is a bus with data on it, nothing very mysterious there. However in order to carry data the signal is modulated in some way or other eg. square waves. Depending the rate of data transmission, the impedence, inductance and capacitance of the connecting cables / tracks can have a significant impact on the rate of data transmission .
    Another interesting concept is twisted differential pairs eg. CAN where the data signal is transmitted in duplicate - one line an inversion of the other to make the bus less prone to interference. Most data lines also have a specific terminating resistance to avoid reflections
