application of delta and wye connection
Discussion in 'Homework Help' started by bug13, Nov 19, 2012.
  1. bug13
    Feb 13, 2012
    1,213
    38
    Hi
    I am studying about delta and wye connection, I have to say AC 3 phase is not my favor subject as I more into electronics.
    so here is my understand of it:
    • wye connection provide two different voltages
    • delta provide more current.
    • wye connection is more suitable for unbalanced load because it's neutral line.
    apart from these, in when should I use a delta connection and when should I use a wye connection?
  2. JDT
    Feb 12, 2009
    658
    85
    Don't understand "delta provide more current"? What does that mean?
    I think the main advantage to the delta connection is that the power is transmitted using only 3 wires instead of 4. So cheaper and makes best use of the copper.
  3. bug13
    Feb 13, 2012
    1,213
    38
    I mean with the same supply, delta connection can provide more current when start
