application of collector-feedback biasing
Discussion in 'Homework Help' started by den, Mar 4, 2006.
  1. den
    Mar 3, 2006
    8
    any?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Is this your question?
    "Is there any reason to use collector-feedback other than to set the gain of a common emitter transistor ampilifer?"
    If I have misphrased your question, can you please restate it?
    hgmjr
  3. den
    Mar 3, 2006
    8
    true.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    I know of no other reason to use a collector-to-base feedback resistor in a common emitter amplifier than to set and stabilize the gain of the transistor amplifier.
    By the term "stabilize", I mean that the collector feedback resistor minimizes changes in the amplifier's gain due to variations in beta due to temperature as well as variations of beta that occur between different transistors bearing the same part number.
    hgmjr
  5. aac
    Jun 13, 2005
    35
    Collector feedback also lowers the output impedance and input impedance of the amplifier, so it can be used to control these. If you include capacitors or inductors in the feedback circuit, you can also control bandwith. If you include nonlinear elements, you can make things like log, exponential, or multiplier circuits.
  6. windoze killa
    Feb 23, 2006
    605
    24
    wow The master of one word questions.
  7. paultwang
    Mar 8, 2006
    80
    Also reduces harmonic distortion a little bit.
  8. Ron H
    Apr 14, 2005
    7,050
    657
    It can also be used for bias stabilization.
