Apparently I'm not that smart and can't turn an LED on in multisim
bertus
Joined Apr 5, 2008
22,278
The led most likely has blown.
Leds are current controlled devices.
You will have to use a resistor in series with the led to control the current.
Also what kind of mosfet do you use?
Standard mosfets will turn on at 10 Volts on the gate.
Logic gate mosfets will work as in your schamatic with the 5 Volts at the gate.
Bertus
Alec_t
Joined Sep 17, 2013
14,330
Welcome to AAC!
I don't use Multisim, but it looks to me as though your probes show a 218uA LED current, so it is 'on' (but not very bright :)). What FET are you using? If it's not a logic-level type it may need about 10V to turn it on properly.
durable126
Joined Feb 20, 2016
56
Hey guys thanks for the reply
This is a generic "ideal" n chanel in multi sim
Its threshold voltage is set to zero in the parameters therefor it should turn on with anything across the gate to source
Also the LED don't blow in the simulator
They are ideal and can take infinite current obviously not in real life but just in the sim
Any other ideas?
No one has any ideas on this?
bertus
Joined Apr 5, 2008
22,278
Could you put a probe directly at the drain of the mosfet?
That way you can see if the mosfet is in conduction.
If the voltage is 5 Volts at the drain, the mosfet is not conducting.
Bertus
JohnInTX
Joined Jun 26, 2012
4,787
I'd try a 2n7000 FET model. That way you know its params (Vgs(th)~=2.1V typ). If all you say is true the LED should be ON but it isn't. Maybe having a Vth == 0V is throwing it off. Try setting it to 2V.
I'd suspect the FET. I'd also put a 240 ohm resistor in series with the LED.
durable126
Joined Feb 20, 2016
56
Thanks for the ideas
I have tried all that. Im a reasonably experienced guy so i did try moving the threshold up just to see if it worked. I also have tried it with a resistor and not a resistor in with the LED.
I have also put a probe on the drain and there is a drop of about 1.5 volts across the LED leaving 3.5 at the drain which is plenty for VDS
Also i have tried exactly the 2n7000, funny you bring that guy up that is exactly what i tried.
Still the same issue. No light
Also just to go way way way back in the debugging i stuck a voltage source on the led to make sure it comes on and of course it does.
I have to be missing something simple here but can't see it
bertus
Joined Apr 5, 2008
22,278
With 1.5 volts accross the led, the led may still be off.
What kind of led did you select?
A white led will need more than 3 Volts.
A red or green led will need about 2 volts.
Bertus
absf
Joined Dec 29, 2010
1,968
I try with proteus and it's woring fine.
If I push the button, the current goes up to 407mA and the drain voltage is 1.5V.
Allen
