In page 92 of the Art of Electronics (or 2.3.2) the author summarized a few quantities derived from Ebers-Moll equation.
- For the small-signal impedance looking into emitter re, why Is(T) is not in the derivative?
- For the temperature dependence, the author considered Ic at constant Vbe and Vbe at constant Ic. How do we take that into account in real design? For example, if Vbe was initially 0.6V and Ic 10uA, how do they change if temperature is incresed by 10 degrees?
- How can I understand the early effect equation Ic = Ico(1 + Vce/Va)? For example, if Vce increases, Ic increases and therefore the voltage drop across the collector resistor should increase, so Vc decreases and therefore Vce decreases. It doesn't make sense to me.
Thanks very much!
Thanks very much!
