AO pump problem
slawolom
Joined Apr 24, 2012
I have a problem with my pool pump. I recently replaced a bearing and when I assembled it back it does not want to start. It spins freely by hand. Also when I turn it by hand under power it picks up the speed and after few seconds you can hear spring on the governor switch (I guess) and the pump starts to work fine. Also it starts without a problem after shut down until the shaft is still rotating at list a little. When the shaft stops, it does not start again
Joined Nov 30, 2010
18,224
Assuming "the spring on the governor" is really a centrifugal switch in series with the start winding, it can get crud in the contacts. That would explain this.
slawolom
Joined Apr 24, 2012
OK I figured it out. AO Smith BN24 motor does not have a capacitor, so there this goes. I talked to the technical support and they suggested a bad contact on the starter switch. I cleaned it , bend the contacts closer together and it started to work fine!!!
