Anyone using Eagle help me again!!
Discussion in 'General Electronics Chat' started by corefinder, Oct 25, 2012.
  1. corefinder
    Oct 6, 2011
    55
    I am making one schematic in eagle but not able to find this NTD2955 or IRF9024 in eagle library. Anyone help me in finding this...
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Making a symbol is one of tasks a CAD engineer should master. Most often and for sure in your case. You can do this by copying and modifying a component that already is in the component database. Take a look at the google search it will tell you how to do it
    http://www.google.com/search?q=creating+symbol+eagle
  3. JMac3108
    Aug 16, 2010
    349
    66
    When I started with Eagle I found some good tutorial videos on YouTube that covered creating new library parts. If you're going to layout PCBs using Eagle then you really need to learn to do this.
  4. BMorse
    Sep 26, 2009
    2,675
    234
    You can also use a similar device with the same footprint, it does not matter if part numbers match (You can always edit the part name and number if needed) as long as the end circuit still has the same function, just look for another P Channel Mosfet to use, just make sure the pinouts are the same as the device you are using.
  5. panic mode
    Oct 10, 2011
    1,330
    305
    no software will have all parts in the library specially since more parts are developed every day. you must learn how to expand libraries from info in datasheets.
