Anyone know what these do here?
Discussion in 'General Electronics Chat' started by nado, Dec 17, 2012.
  1. nado
    Dec 17, 2012
    40
  2. #12
    Nov 30, 2010
    16,705
    7,355
    Big download, 25 megabytes. It would help if you told us to which of the 180 pages you refer.
  3. nado
    Dec 17, 2012
    40
  4. #12
    Nov 30, 2010
    16,705
    7,355
    Go Advanced, manage attachments, browse, click on it, open, upload.
    and don't forget to name a page number.
    nado likes this.
  5. tubeguy
    Nov 3, 2012
    1,157
    197
    Some Jfets are normally 'On' and are biased to turn the 'Off"
  6. nado
    Dec 17, 2012
    40
    Thanks for the respond.
    Honestly though, as a beginner, I don't quietly understand what you said.
    Could you point to a tutorial or example web page explaining in detail? Any webpage that has JFET's Source and Drain shorted circuit.
    Thanks again.
  7. #12
    Nov 30, 2010
    16,705
    7,355
    Could you point to a page in the instruction manual that has these jfets on it?
  8. atferrari
    Jan 6, 2004
    2,670
    785
    Your image is hard to read. No, thanks.
  9. nado
    Dec 17, 2012
    40
    Page 9-3.
    I attached the pdf page.
    Thank you.
  10. MrChips
    Oct 2, 2009
    12,648
    3,458
    The FETs are used as diodes for over voltage protection.
  11. nado
    Dec 17, 2012
    40
    That's my implied question. Why do they use JFET instead of diode? Did the Fluke engineers think it is easier to their eye or did they think it is cheaper? There must be some advantage instead of using the diode.
  12. #12
    Nov 30, 2010
    16,705
    7,355
    Somewhere deep in the filing cabinet of my mind, these are labeled, "low leakage" diodes.
    ps, I find your pdf to be very good quality. I was able to zoom it 500% and it did not get fuzzy.
  13. tubeguy
    Nov 3, 2012
    1,157
    197
    Thanks for the pdf.
    If you were talking about the 7 fets wired as diodes I think the schematic shows why they test shorted D-S in-circuit. :)
    Never mind ... I think I mis-understood your original statement
    This will help explain Jfets:
    http://www.allaboutcircuits.com/worksheets/jfetamp.html
  14. nado
    Dec 17, 2012
    40
    Thanks #12 for kind words. I learned how to upload the file and next when I need a solution, I have to sit and look aorund a little longer than just shooting the help.
    Thanks tubeguy for the reading suggestion, I am sure I will learn more about this good article.
  15. #12
    Nov 30, 2010
    16,705
    7,355
    @tubeguy: Thanks for the reference. I would like to point out that a jfet is an excellent constant current device, as demonstrated in the second oscilloscope view. They are actually born as constant current devices, and there is a method, using only one resistor, that cancels their temperature drift. If nado wishes to know this method, I will demonstrate how to do it.
  16. nado
    Dec 17, 2012
    40
    @#12,
    Please so. I am sure it will help all of us as well as me.
    Regards,
  17. Ron H
    Apr 14, 2005
    7,050
    657
    I agree that the ones with drain and source connected are used as low leakage diodes.
    The ones with gates connected to LM339 outputs are analog switches.
    CL301 is a current sink.
    QQ314 is a differential amplifier.
  18. #12
    Nov 30, 2010
    16,705
    7,355
    In the graphs provided by the manufacturer, there is one called, "Transfer Characteristics". I can't pull one out of a PDF so I drew one. You can see that for all 3 temperature curves, there is a point where they all cross each other. On this graph it is about -6.4 volts. If you place a resistor on the source lead and connect the gate to the other end of the resistor, the jfet will pass the same current, no matter what the temperature is, as long as there is enough voltage to keep the jfet in its operating range.
    A hair dryer is a valuable tool to find out whether you have the correct resistance in the source circuit.
    tubeguy likes this.
  19. MrChips
    Oct 2, 2009
    12,648
    3,458
    Yes, I think I have a data sheet with a chart that shows the zero temperature coefficient point.
    I will post it when I find it. I actually used that feature in my undergrad final year project.
  20. Ron H
    Apr 14, 2005
    7,050
    657
    I don't mean to be rude, but why are we discussing zero TC current sources?
