Anyone know what kind of connector this might be?
Discussion in 'General Electronics Chat' started by bbiandov, Jul 11, 2016.
  1. bbiandov
    Thread Starter Active Member
    Nov 24, 2007
    31
    Hi everyone,
    It is the input of an electro-mechanical break of a servo motor. It takes mains power. I looked everywhere and I can't see a similar looking connector. Obviously I am looking for the mating connector so I am guessing a female flat looking with a double chamfer on one end and plastic locking ears on both sides of the body.
    ~B
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Yeah. It is a Molex Connector. It is often used for power cables because you can't mate them backwards.
  3. gerty
    Aug 30, 2007
    1,154
    304
  4. Techno Tronix
    Member
    Jan 10, 2015
    140
    10
    Yes, It s Molex connector.
    But why can't mate them backward?? Molex provides complete design flexibility for flat cables.
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Because you can't mate a triangle with a square. I dunno, just sayin'
  6. KeepItSimpleStupid
    Mar 4, 2014
    1,285
    225
    Molex for sure. The EARS can be purchased on or off. They fold back and become a snap in the back of the panel in a rectangular hole. Used inside equipment and for disk drives. Those Molex can be cross-pinned mix and match. Usually male pins go in female housings
  7. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,705
    1,300
    Note that this connector style is available with at least two different pin (and body) sizes. Images and drawings without dimensions are almost identical. Also, AMP (now Tyco) makes intermateable parts.
    ak
  8. GopherT
    Nov 23, 2012
    6,322
    4,050
    Sure you can configure them but if you leave a plug and a socket hanging for an end-user, there is only one way to plug them.
  9. Techno Tronix
    Member
    Jan 10, 2015
    140
    10
    Which way? Can you suggest me?
