anyone know ASM?
Discussion in 'Homework Help' started by ABoul, Dec 25, 2009.
  1. ABoul
    Mar 30, 2009
    15
    the question is attached. i honestly have no clue how to do any of it; i would appreciate it if someone could briefly walk me through what they know.
    EDIT: the only thing i could manage to work out is that in part (i), after the first 3 lines the stack pointer is now at 9998 with the top position (9999) being Y.
      File size:
      59.2 KB
      43
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    This is obviously homework.
    I can get you started. When you call a subroutine the two byte values that is the return address is put on the stack. The stack is a temporary storage location for addresses, when you run the return command these values are pulled from the stack and used to take the program back where the subroutine was called.
    Like I said, the stack stores addresses on a temporary basis, it uses Last In First Out. Basically the last address stored there is the first to pop out (BTW, this directly relates to the POP command).
    There is a lot of variation between assy languages, though they have certain basics in common. You might specify what CPU you are using.
    I may have repeated what you already knew. If so you need to get more specific with your question(s).
  3. ABoul
    Mar 30, 2009
    15
    for part (i) is this the answer?
    line number | SP | content of stack
    100 | 9999 | <nothing>
    102 | 9999 | <nothing >
    104 | 9998 | Y
    106 | 9997 | <?>*
    *don't know what to put here
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    PUSH is a stack operation
    PULL is a stack operation
    JSR stores something on the stack
  5. spinnaker
    Oct 29, 2009
    5,081
    1,180
    BeenThere,
    I take it that "something" is a hint? ;)
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It certainly is.
  7. ABoul
    Mar 30, 2009
    15
    the next line?
  8. spinnaker
    Oct 29, 2009
    5,081
    1,180
    To be more correct, the next address.
