Anyone here ever play with fluidic logic?
Discussion in 'General Electronics Chat' started by KL7AJ, Jul 20, 2015.
  1. KL7AJ
    Thread Starter AAC Fanatic!
    Nov 4, 2008
    2,043
    293
    nsaspook likes this.
  2. GopherT
    Nov 23, 2012
    6,305
    4,029
  3. BillB3857
    Feb 28, 2009
    2,402
    348
    The closest I ever came to it was with a Moog Hydrapoint milling machine. It used compressed air to read the mylar punched tape to define machine position. The air pressure was then applied to air to hydraulic transducers which ported hydraulic oil to move pistons in a hydraulic cylinder. The cylinders were side ported with switch plates. The plates were stacked and moved individually to open a specific position along side the cylinder. The piston would move to a point that it would cover the open port. A buildup of pressure would indicate that the position had been reached and the next portion of the program would be activated.
  4. KL7AJ
    Nov 4, 2008
    2,043
    293
    Sounds like a player piano! :)
  5. BillB3857
    Feb 28, 2009
    2,402
    348
    The tape reader was pretty close to a player piano. It was a block with holes for each possible punch position of the fixed format tape. There was so much color coded vinyl tubing running everywhere. Without the color coding, it would have been near impossible to troubleshoot.
