Anyone has an idea for this Logic
Discussion in 'General Electronics Chat' started by jic222013, Feb 26, 2014.
  1. jic222013
    Feb 26, 2014
    Im using logic gates to do the logic then do the PLC
    Let’s say I have 3 motors, Motor A, Motor B and Motor C “All could be online, offline”
    If I turn-on Motor B first, it is going to be Primary motor.
    And If I turn on Motor C next, it is going to be Secondary
    And if I turn on Motor A, it should be Tertiary..
    If Motor C turned off then Motor A should become Secondary and Motor C will be tertiary even if it is in OFF mode and so on …. I will have six scenarios
    Motor A Motor B Motor C
    Primary Secondary Tertiary
    Primary Tertiary Secondary
    Secondary Primary Tertiary
    Secondary Tertiary Primary
    Tertiary Primary Secondary
    Tertiary Secondary Primary
  2. GopherT
    Nov 23, 2012
    6,335
    4,082
    Could you put some context around this? Like, why do you need this? Is the primary, secondary, tertiary lable for software or do you bed a complete solution in discrete logic chips for some reason.
    A better explanation will get you an answer vs ignored.
    inwo likes this.
  3. inwo
    Nov 7, 2013
    2,435
    315
    Like a 3 stage pump alternator?
  4. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    what is the reason for (discrete?) logic gates, why not go directly to PLC?
    Is this PLC as in Industrial definition or a μp?
    Max.
  5. Lourens
    Jul 16, 2012
    14
    Use a state diagram:
    You have 6 states. From any one state you can go to 2 other states.
