anyone got any good examples of using a ds1820?
Discussion in 'Embedded Systems and Microcontrollers' started by bluebrakes, Jun 18, 2010.
  1. bluebrakes
    Thread Starter Active Member
    Oct 17, 2009
    245
    7
    I'm looking to make a dual thermometer for my car's intercoolers, so i can monitor intake temp, etc...
    i would like to use a pic 16f628 for this and I just can't seem to find an example with decent source code, etc...
    does anyone have any suggestions?
    thanks.
  2. coldpenguin
    Apr 18, 2010
    165
    9
    What language are you writing it in? Which compiler?
    The basic code you would need for 1 1-wire device is below, you would need to implement a search algorithm if desired to have two on the same bus (read the datasheet for the DS1820). I am afraid that I don't comment my code when I program, but the below should be relatively straight forward. It works with the hitech compiler. The timing defines might need to be changed if you are not using a 48MHz crystal. It will reset the bus, send out a request rom, read the rom address in then reset the bus. It will then perform a match rom, start calculation and then pause for 90us. This should be enough if not using parasitic power. It then performs a reset, match rom, then read scratchpad.
    Code ( (Unknown Language)):
    1.
    2.  #define TA 7
    3.  #define TB 70
    4.  #define TC 65
    5.  #define TD 12
    6.  #define TE 11
    7.  #define TF 60
    8.  #define TG 0
    9.  #define TH 500
    10.  #define TI 77
    11.  #define TJ 450
    12.
    13.  #define TPIN TRISD7
    14.  #define DPIN RD7
    15.  bit prescence = 0;
    16.
    17.  void One_Wire_High(){
    18.  DPIN=1;
    19.  TPIN=1;
    20.  }
    21.
    22.  void One_Wire_Low(){
    23.  TPIN=0;
    24.  DPIN=0;
    25.  }
    26.  bit Get_One_Wire_Bit(){
    27.  TPIN=0;
    28.  char a=DPIN;
    29.  TPIN=1;
    30.  return a;
    31.  }
    32.
    33.  int One_Wire_Get_Byte()
    34.  {
    35.     unsigned char n, i_byte, temp, mask;
    36.     for (n=0; n<8; n++)
    37.     {
    38.        TPIN=0;
    39.        DPIN=0;
    40.    __delay_us(TA);
    41.   TPIN=1;
    42.   __delay_us(TE);
    43.
    44.        temp=DPIN;
    45.        if (temp==1)
    46.        {
    47.          i_byte=(i_byte>>1) | 0x80; // least sig bit first
    48.        }
    49.        else
    50.        {
    51.          i_byte=i_byte >> 1;
    52.        }
    53.        __delay_us(TF);
    54.     }
    55.     return(i_byte);
    56.  }
    57.
    58.
    59.  bit One_Wire_RS(void){
    60.  One_Wire_High();
    61.  __delay_us(TG);
    62.    prescence = 0;
    63.  One_Wire_Low();
    64.    __delay_us(TH);
    65.  One_Wire_High();
    66.  __delay_us(TI);
    67.  if (Get_One_Wire_Bit() == 0 ){
    68.  prescence=1;
    69.  };
    70.
    71.   __delay_us(TJ);
    72.  return prescence;
    73.  }
    74.  void One_Wire_Out_Bit(int a){
    75.  if(a==1){
    76.  One_Wire_Low();
    77.  __delay_us(TA);
    78.  One_Wire_High();
    79.  __delay_us(TB);
    80.  }else{
    81.  One_Wire_Low();
    82.  __delay_us(TC);
    83.  One_Wire_High();
    84.  __delay_us(TD);
    85.  }
    86.  }
    87.
    88.
    89. void ()main code{
    90.
    91.  One_Wire_RS();
    92.
    93.  if(1 == One_Wire_RS()){
    94.  One_Wire_Out_Byte(0x33);
    95.  for(n=0; n<8; n++)
    96.     {
    97.        adr[n]=One_Wire_Get_Byte();
    98.     }
    99.  char crc=One_Wire_Get_Byte();
    100.
    101.
    102.  One_Wire_RS();
    103.
    104.  One_Wire_Out_Byte(0x55);
    105.  for(n=0; n<8; n++) // followed by the 8-byte ROM address
    106.     {
    107.        One_Wire_Out_Byte(adr[n]);
    108.     }
    109.  One_Wire_Out_Byte(0x44);
    110.
    111.  __delay_us(90);
    112.  One_Wire_RS();
    113.  One_Wire_Out_Byte(0x55);
    114.  for(n=0; n<8; n++) // followed by the 8-byte ROM address
    115.     {
    116.        One_Wire_Out_Byte(adr[n]);
    117.     }
    118.  One_Wire_Out_Byte(0xbe);
    119.  for(n=0; n<9; n++)
    120.     {
    121.        d[n]=One_Wire_Get_Byte();
    122.     }
    123.  mytemp=d[0];
    124.  d[0]>>=1;
    125.
    126. //d[0] is now the temperature, and bit0 of mytemp defines whether you add 0.5 to it.
    127. }
    128.
    129.
    I should warn you though, for some reason, running One_Wire_RS() in my code, is setting RD6 to be low output. I am using a 16f877a
  3. t06afre
    May 11, 2009
    5,939
    1,222
    The DS1820 is no longer in production, but the DS18S20 is. Just as you know it. I also think you will find something if you Google -> ds18s20 microchip Or something like it. The method used for data transfer is named bit-banging I think.
    Good luck :)
  4. coldpenguin
    Apr 18, 2010
    165
    9
    Some of us still have a stock of DS1820 to get through though, before we move onto the flashy DS18b20 or the DS18s20 with their extra bits of precision.
  5. bluebrakes
    Oct 17, 2009
    245
    7
    i'm using mplabs but also a few c compilers should that help...
    sorry it's the ds18b20 i'm using too.
  6. coldpenguin
    Apr 18, 2010
    165
    9
    Well, in theory the code I put up should be pretty close to working, the scratchpad is different though I think.
  7. MMcLaren
    Feb 14, 2010
    759
    116
    Yeah, they're different. The DS1820 and DS18S20 produce a 9-bit temperature result (0.5°C resolution) where the DS18B20 produces a 12-bit temperature result (0.0625°C resolution).
    I posted a 16F690 + 2x16 LCD + DS18B20 (assembly language) example on another Forum recently (below). You would have to make hardware and software changes for a '628A and dual sensors.
    You should be able to find several examples on the Internet too.
    Regards, Mike
  8. rajbex
    Nov 2, 2009
    22
