anyone can help me?
Discussion in 'General Electronics Chat' started by spidermanIIII, Nov 25, 2013.
  1. spidermanIIII
    Nov 22, 2013
    76
    I need to do footprint for variable capacitor in Proteus please
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    What a dumb title for a post!
    I can think of about a dozen types of variable capacitors, and hundreds of footprints. You need to be way more specific.
  3. djsfantasi
    Apr 11, 2010
    2,900
    874
    "Anyone can help me", "help me" and "please anyone help me" are the titles of all of this member's threads. S/he needs to learn how to become more original even if there is a language barrier.
  4. spidermanIIII
    Nov 22, 2013
    76
    10pF-280pF 2J type & 0pF-10pF Trimmer
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    So do you have the trimmer in hand, or a datasheet which shows its physical dimensions?
  6. t06afre
    May 11, 2009
    5,939
    1,222
    A part of any ECAD operator job, is to be able to create a aymbol/footprint then needed.
    mcgyvr likes this.
  7. spidermanIIII
    Nov 22, 2013
    76
    I want to show me any footprint for any variable capacitor you choose
  8. WBahn
    Mar 31, 2012
    18,085
    4,917
    Do you have a footprint available for typical resistor?
    There, that's the footprint for the variable capacitor I just chose.
    Go to Google. Type in variable capacitor footprint. Click the link with the pretty pictures.
  9. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    if stringsearch(thread_title,"help"|"anyone") button.submit_thread.enable=FALSE;
    strantor and tshuck like this.
  10. WBahn
    Mar 31, 2012
    18,085
    4,917
    Not that easy.
    A thread titled, "Need help understanding common-mode gain" is not at all unreasonable. Neither is, "Can anyone tell me where my attempt to match impedances is going astray?"
    There are certainly better titles that don't use "help" or "anyone", but the point is that perfectly reasonable titles can and do use these and other red-flag words.
  11. takao21203
    Apr 28, 2012
    3,578
    463
    Yes correct but it would be possible to disable posting when certain titles are entered.
    And if the word help is present, what is gained?
    Wouldn't "Common mode gain" be sufficient?
    Most forum posts here are somehow having the purpose of obtaining help.
    Or at least a pop-up with a Captcha:
    If everyone is using "Need urgent help" as thread title, it becomes impossible to understand about the threads from the title. We don't want to restrict or censor your posting but please try to write the thread title differently, or alternatively, enter the Captcha now.
    Also "anyone", it implies otherwise there would be a limitation who is allowed to reply or even to read. It is not really neccessary for a thread title, even if it is perfectly valid in spoken language.
    I'd really like to see a pop-up if certain words are used, including "urgent", "anyone", "help".
    And also "Guys" as first word or "thank you", "Regards" as last word.
    Either everyone is using greeting formula or Thank-you signature or no one. It is not correct to use on a forum post (the first thread post done by OP).
    Same here, not disabling it, but ask for a Captcha and remind to check the wording.
  12. spidermanIIII
    Nov 22, 2013
    76
    I searched but I found nothing
  13. t06afre
    May 11, 2009
    5,939
    1,222
    This thread has lost its momentum because you have not posted any information on how this component look like. Before you do that you are only wasting your time. Why not take a picture of it and some measurements with a slide caliper. If you do not have the datasheet. But the datasheet would of course be the best
  14. WBahn
    Mar 31, 2012
    18,085
    4,917
    You are looking for ANY capacitor footprint.
    You did what I suggested, which is type in "variable capacitor footprint" in Google and select the Google Images link -- the one with the pictures. And you found nothing. I see about a dozen footprints on the first page alone.
    Perhaps it is time to consider a less challenging career choice.
    Or, perhaps it is time to make a more specific post of just what you are trying to achieve.
    Take your pick.
  15. killivolt
    Jan 10, 2010
    432
    351
    If I can do it, anyone can……Here
