Are you learning how to use these instruments? And are these some examples of usage?Anyone can show me how to show a 3kHz 1V peak to peak Sin wave with signal generator and CRO?
and adjust a power supply to obtain 15V DC Voltage output with digital multimeter?
I hope with a aid photo to show these two exp. Thanks all.
Surely you have or will get the opportunity to work with the instruments before this test you are preparing for, correct? That is your best time to learn how to do these things -- when you are actually working with the equipment.Yes! I'm learning these instruments
I will see the CRO, signal generator, power supply, digital multimeter on the desk.
I need use CRO and signal generator to complete question 1.
and I need use power supply and digital multimeter to complete question 2.
and I attach the picture about question 1, I want to know to cable connection and step by step
to show a 3kHz 1V peak to peak Sin wave with signal generator and CRO.
Thank you all.
