It is a PLL with VCO. I want just a VCO. Thanks for your help.Hello,
That will be hard to find.
A 74hct4046 (a 4046 derivative) will come the most close:
http://search.digikey.com/us/en/products/CD74HCT4046AM/296-9275-5-ND/376938
It will go upto 38 Mhz.
Bertus
Thanks. But I found a better one by dropping the L of "74LS124". It is SN74S12474LS124, 74LS324, 74LS624 - 74LS629
to 20MHz, maybe short of your range.
You could add a frequency doubler or phase-locked loop.
It is far from clear that a digital part will be suitable for the intended application. It has now been over a decade since the post before yours and since the TS was last seen.The 74S124 dual TTL VCO I.C. is still around and can operate up to 60 Mhz. Check it out.
by Jake Hertz
by Aaron Carman
by Duane Benson
by Jeff Child
