I recently bought (at a HAMfest) an old Motorola M68HC05PGMR board with complete documentation. It even came with the IASM05 software on 5.25 floppy! This is (evidently) the original board from 1989, not the M68HC05PGMR-2. it also came with one programable chip, but not with a UV source for erasing.
I have no experience with embedded systems, and very little with any type of programming. I bought this just as a lark, thinking it might be fun to play with.
I anticipate trouble with this floppy- even if I can find a 5.25 drive, these old floppies are often damaged/not readable. I googled around and it appears the IASM05 software is not to be found anywhere. AFAIK, the later versions are proprietary. Does someone know of an easily available software that will work with this older version programmer?
In your opinion, is this board and documentation completely worthless? Would you recommend my not bothering with it due to its obsolescence? I.e., is it so primitive/incompatible by today's standards that it is now nothing more than a museum piece?
Thanks,
Keith Ostertag
Thanks,
Keith Ostertag
