I'm working on a SketchUp drawing of a hub for my PEX Octopus project, see here. The goal is to make the device by 3D printing.
This is my first use of any 3D software and while I'm very handy with 2D drawing, it's been a steep learning curve. I feel like I'm getting very close but I'm stuck. I have overlapping solid objects that I would like to merge into a single solid object. You can see this as the lines (residual edges) in the center of the hub, see image of drawing.
I'm familiar with SketchUps solids tools, and I was able to use the Subtract tool to punch a hole through the middle of the hub (to spare plastic when printing). But the Union and Outer Shell tools do not perform as I expect. The lines don't go away and the shapes don' merge into one.
In the image you can see the hub (green), a mock piece of 5/8" PEX tubing (orange), and the white cylinder I used to punch the hole. I've also duplicated one of the 8 solids that, when rotated and copied, produced the 8-legged hub. You'll notice that the hole in the center - into which the PEX tubing will fit - extends from the cylindrical leg into the rectangular body of the hub.
The SketchUp file is attached
