Any reason NOT to use paper clips for bridges on stripboard?
Discussion in 'General Electronics Chat' started by AgeingHippy, Nov 28, 2010.
  1. AgeingHippy
    Nov 28, 2010
    16
    Hi All
    I am planning to use paperclips - bent & cut to the right length - to form bridges from one track to the other on my stripboard stepper driver.
    Is there any reason for me NOT to use them?
    Further, the wire of a paperclip seems pretty thick - would it be adequate to carry the 12v for the motor (max 4 amps)?
    Thanks for any advice
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Paper clips do not take solder very well since most of them are chrome plated.
    hgmjr
  3. AgeingHippy
    Nov 28, 2010
    16
    ah! thanks for that info. Unfortunate :( but there you have it.
    What guage wire would you reccomend I get for my bridges? Also, should I get single strand wire or multiple strand. What value the differences?.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Depends on the current you are likely to encounter.
    For currents on the order of 1 amp or less you should be good with 20 to 26 guage wire. Solid wire is easier to work with than stranded wire. Both will work fine.
    hgmjr
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Have easy access to house wiring wire? It is 14-16 gauge and solid copper.
    (howdy again)
  6. AgeingHippy
    Nov 28, 2010
    16
    Hi Bill
    In fact I do - or at least I think it is house wiring wire. But I am not too impressed with the work the landlord has done on this property so I cannot be sure it is the right stuff.
    The ground seems to be mild steel perhaps and is uninsulated whereas the live and earth wires are insulated in red and black resp. and have 5 strands, each looking like about 0.75mm in diameter. All of it is insulated in a grey sheath.
    Wohoo - well, I guess this will do and the 100 paperclips I purchased yesterday will just have to wait for paper to be clipped... :)
  7. spinnaker
    Oct 29, 2009
    5,066
    1,176
    His neighbors house has plenty! :)
  8. KMoffett
    Dec 19, 2007
    2,584
    234
    Bill,
    How are you going to get 14 or 16 AWG wire to fit through the holes in perf'd stripboard? :eek: More like 20 or 22 AWG solid hook-up wire or wire from CAT-5 cable or residential telephone wire.
    Ken
