I need a PCB making up, there really isn't alot to it:
1 8 pin dip
pin 1 unused
pin 2 - 2 resistors come off (to led x2)
pin 3 - 2 resisitors come off (to led x2)
pin 4 gnd
pin 5 2 resistors come off (to led x2)
pin 6 2 resistors come off (to led 2x)
pin 7 unused
pin 8 Vcc
I need a small board, as small as possible
basically each of the 4 used pins drives 2 leds and each led needs its own resistor, the led points and resistor points would need through hole solder pads as would the 8 pin dip.
i would design the board but if i understand it the traces need to be X amount thickness.
it only needs to be single sided.
Just wondering if anyones able to build a board for me and what it would cost?
1 8 pin dip
pin 1 unused
pin 4 gnd
pin 7 unused
pin 8 Vcc
