the plate on top says Montegomery Wards Diamond
with sparks engraved on it.
The little lever on the top center is a switch handle that comes
in contact with the heads of the small screws below it. they in turn are wired to the large lugs on the top.
the two circles on top left next to the strap loop are set screws
that are terminals for the earphone.
the hole in front of the large lug on the left has a plunger that
activates a reed switch below it.
the generator puts out 24 volts at an easy crank
not sure of the current output but will easily light a 12 volt panel light
It should be very easy to rejuvenate if I knew what the heck
is is supposed to do!
Any ideas?
Any ideas?
