I have a classic Lotus with a fuel guage needle that bounces on rough roads. It's not the guage that is the problem, it is the sender bouncing in the fuel tank, which is a well known problem. I need a circuit that will average out the signal from the sender with a time constant of a couple of minutes. The long time constant will keep the guage from moving even around long bends.
This would be a simple smoothing circuit but for the following problem. I don't want to wait several minutes when I turn on the engine to see how much fuel I have. Any ideas for a circuit that will instantly fix the output at the input voltage as soon as it is turned on and thereafter give an accurate average the input?
