Any IC chip for converting I2C to SPI
Discussion in 'Embedded Systems and Microcontrollers' started by oteggis, Mar 22, 2015.
  1. oteggis
    Mar 22, 2015
    I am working on a project and I need a chip which I can use to convert I2C to SPI
    Any suggestion?
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
  3. oteggis
    Mar 22, 2015
    Hello John,
    Thanks for your reply. In the design, an MCU is communicating with two chips, One has I2C and the other SPI.
    So I want to keep the communication through SPI since the system to be designed has to communicate with another system through SPI. That is why I want to convert the I2C to SPI so that I can keep all communication in SPI.
    Kind regards
    Soso
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
  5. oteggis
    Mar 22, 2015
    Thanks John, I will just use an MCU with both SPI and I2C peripherals, so that the MCU can communicate with both chips effectively. I am working with LTC4274A and LAN8720 in a PoE PSE system to provide power management
