Any free wiring diagram or general drawing software?
Discussion in 'General Electronics Chat' started by tpny, Mar 25, 2013.
  1. tpny
    May 6, 2012
    216
    i need to draw some wiring/connection diagrams. any free software? Thanks!
  2. MMH
    Member
    Feb 8, 2013
    143
  3. varun_kanpur
    Mar 26, 2013
    ExpressPCB is a very good free software. I use it to make PCBs.
  4. ScottWang
    Aug 23, 2012
    4,929
    777
  5. KMoffett
    Dec 19, 2007
    2,584
    234
    I'd vote for ExpressPCB too. Pretty intuitive. Not a huge library, but very easy to make any new component that isn't there.
    Ken
  6. ErnieM
    Apr 24, 2011
    7,436
    1,626
    EpressPCB is a good starters choice. I still use it some.
    Kicad is a great package that can also take you thru PCB designs. It has as steep a learning curve as any other full featured layout program.
    LTspice is also free and a pretty good simulator, not just with LT parts. I'm just starting to use it and like it.
  7. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    I agree with the others--ExpressPCB is a good place to start, but don't get hung up on it if you plan to do more extensive wiring and/or PCB design. For that I'd recommend Eagle, KiCad, or DIPtrace. All of them have free versions.
    If it's a simulator you're looking for, try LTSpice, from Linear Technology, like ErnieM suggested. You can also get free trials of Multisim, which is actually my preferred simulating software (right behind Proteus ISIS). However, both ISIS and Multisim will require you to purchase the software if you want to keep using it after a certain amount of time.
    Hope this helps!
    Matt
