Any free CAD software that someone could kindly recommend?
Discussion in 'Electronics Resources' started by monkeyhead, Apr 26, 2008.
  1. monkeyhead
    Thread Starter Active Member
    Mar 5, 2007
    45
    Hi there,
    I've build by circuit onto strip board, and have got an enclosure for it. However I need to produce some accurate drawings of the finished product. (As its a college project)
    Unfortunately due to many reasons and financial impactions Autocad is out of the question. Also my teacher left half way through the year and a replacement couldnt be found!
    Is there any free cad software out there that anyone knows of?
    Preferably 3D, and something which can produce orthographic drawings.
    Much obliged,
    Matt:)
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
  3. monkeyhead
    Mar 5, 2007
    45
    Nope, I'll take a look into it though! Thanks :)
  4. Caveman
    Apr 15, 2008
    471
    Alibre is a 3d parametric modeller. The Xpress version is free.
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    cumesoftware does a lot in 3D modelling. I'm not sure if the packages he uses (and develops for) are suitable for you projects, but you may be advised having a look at his site: http://www.cumesoftware.eu.org/frameset.htm and check his 3D Anim8or modelling section from the menu on the left. He runs a forum where you can ask questions about his models and the softwares. It is free to use too.
    Might be worth considering.
    Dave
