Any danger to running an AC motor without a run capacitor?
Discussion in 'General Electronics Chat' started by MrSoftware, Apr 2, 2016.
  1. MrSoftware
    Thread Starter Active Member
    Oct 29, 2013
    545
    133
    The exhaust fan in my garage was just humming, not running. If I flip the fan with my hand it will slowly speed up to about 1/2 of normal speed. On further inspection the run capacitor is swollen and deformed, so I think this is the problem. It's a small 150w 110v AC motor, the run cap is 10uF 250vac rated. I've ordered a new one, but is there any risk to the motor if I run it as-is until the new one arrives? It sounds happy, but it is running about 1/2 of normal speed.
  2. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,845
    1,311
    I don't advise it -- The unit will run hot with significant liability to degradation of the field (stator) winding insulation ...
    Best regards
    HP
    MaxHeadRoom likes this.
  3. #12
    Nov 30, 2010
    16,671
    7,314
    Right there is the crux of the biscuit. An AC synchronous motor that can't synchronize is not developing the back EMF to minimize the stator current and that larger than normal current will be wasted as heat instead of motion.
    cmartinez likes this.
  4. shortbus
    Sep 30, 2009
    4,092
    1,673
    May be wrong in this answer, but, are you sure the capacitor is a "run" capacitor? Most small AC motors use a "start" cap not a run cap. And manually turning the shaft to get it to run makes it sound more likely that it is a run cap.
  5. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    My experience is the opposite, generally motors over 1hp use a start capacitor, some together with a run cap.
    Under 1hp are typically just a start/run combined (single cap) and remain in circuit.
    Induction motors cannot run in synchronism , but must have slip frequency (min ~5 cycles)
    Giving a motor with a bad start cap a spin at turn on provides just enough out of phase condition to come up to speed in order to function.
    Max.
  6. #12
    Nov 30, 2010
    16,671
    7,314
    I should have said, "induction" motor. Yes, they slip a little, but 50% is really bad.
  7. MrSoftware
    Oct 29, 2013
    545
    133
    I think your explanation is what happened. I noticed the fan was dead silent and not moving, so I power cycled it and that's when it started humming. So it must have over heated and the thermal protection tripped, and was reset when I power cycled it.
    It must have been degrading for some time because the time it was taking to go from off to full speed seemed to be getting longer, but it always seemed to get up to full speed so I didn't really pay much attention to it. Until today. ;)
    I will say after going through about 1 fan per year (they run almost 24/7) I found this one and it has been solid as a rock for about 8 years, very high build quality and it runs smooth and quiet. Hopefully this run cap will fix it.
  8. #12
    Nov 30, 2010
    16,671
    7,314
    I used to see this several times a year. Arrive at dead air conditioner, the outside fan is not moving and too hot to touch. Poke it with a stick to be sure the bearings are still good, replace the capacitor, and let it cool off. Bingo. That's a $4 capacitor to save a $100 motor.:)
  9. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    It has become common knowledge among the importers of Chinese equipment that they can pretty much expect a start capacitor failure within the first 6 mths to a year on any AC motors.
    Replaced with a reliable make.
    Max.
    cmartinez and #12 like this.
  10. crutschow
    Mar 14, 2008
    13,482
    3,369
    I can't help but wonder, why a garage exhaust fan runs near 24/7. :confused:
    But if you want to use the fan before you've installed a replacement capacitor, you might want to try removing the old capacitor and the see if it comes up to speed after you give it a spin.
  11. MrSoftware
    Oct 29, 2013
    545
    133
    It minimizes the gasoline fumes in the garage, plus it maintains negative pressure in the garage which keeps any remaining fumes out of the house. With all the lawn equipment Plus the motorcycles plus the boat motor , some kind of ventilation is needed and this actually does a really nice job and almost eliminates the gasoline fumes in entirely. Gas fumes are heavy so the air pick up is down on the floor.
  12. Hypatia's Protege
    Mar 1, 2015
    2,845
    1,311
    An attached garage?!?!?:eek:--- Your structure insurers are more forbearing than mine!:):):D
    Best regards
    HP:)
  13. MrSoftware
    Oct 29, 2013
    545
    133
    The garage is built for cars, which hold a ton more gas than all those other things combined! Plus here anything left in a shed would be stolen, or rusted to pieces by the next year.
    Hypatia's Protege likes this.
  14. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    Might be easier to buy a canary?:)
    Max.
    Hypatia's Protege and #12 like this.
  15. Hypatia's Protege
    Mar 1, 2015
    2,845
    1,311
    I hear ya!:cool: -- It's just that, in my case, my structure underwriters won't let me place vehicles (nor other fuel powered machinery) within 50 yards of my main building! --- And I've never 'had' a fire nor made a claim of any sort!:(:(:(
    Best regards
    HP:)
  16. #12
    Nov 30, 2010
    16,671
    7,314
    Interesting. My shed is 43 feet from the house, and the house originally had a garage where there are now 2 bedrooms. You can't park much closer than inside the house!:D
  17. Hypatia's Protege
    Mar 1, 2015
    2,845
    1,311
    Sounds (too) familiar!:eek::rolleyes: --- Do you, perchance, hail from NE Minnesota? (rhetorical question:cool:)
    TTFN
    HP:)
  18. Hypatia's Protege
    Mar 1, 2015
    2,845
    1,311
    :confused::confused::confused: -- Yebut -- my 'main building' is my house (i.e. residence):):):) --- Can it be? A case of 50 states separated by a single language?!:eek::oops:
    Best regards
    HP:cool:
  19. #12
    Nov 30, 2010
    16,671
    7,314
    Apparently. I only have one house/home/main building/residence. If you can't figure out which one (out of one) it is, we definitely have a language problem.
  20. Hypatia's Protege
    Mar 1, 2015
    2,845
    1,311
    One of us (Probably me:oops:) is under some misapprehension...
    My response was in reference to the below quoted text:
    Best regards
    HP:)
