The lousy old LM324 is one of the oldest and noisiest (hissss) opamps ever made. I think you see its noise on the graph.
The 10k resistor feeding the 15nF capacitor is a lowpass filter which is supposed to reduce the response at 1066Hz to -3dB and cut higher frequencies more but your graph doesn't show it.
Maybe your signal is turned off and you are looking at the amplitude of the opamp's noise for the different frequencies. The LM324 has a very poor high frequency response.
I agree with Veritas. Jaywin you have to understand that in electronics you cant have the perfect values you would like. The thing you have to have in mind is that for every circuit you design you need to design that circuit with an accuracy sufficient to make the job. But you cant take the perfect values you imagine.
If you use a modern low noise opamp like an OPA134 single, OPA2134 dual or OPA4134 quad then you probably won't see the noise on your graph. Their bandwidth is a lot wider also.
