Hi everyone,
can you please suggest a better circuit for a sine wave and triangular wave generator
Better than what? What is your target frequency range? Output impedence, peak-to-peak or rms voltage (fixed or variable voltage)? Budget?Hi everyone,
Better than what? I assume you want to vary frequency. If so, over what range?Hi everyone,
Actually I'm trying to build a PWM circuit for a AC drive, so i need a Carrier (triangular) signal as well as Reference (sine) signal. so that I'll compare the both and will give the proper pulses to obtain AC SupplyBetter than what? What is your target frequency range? Output impedence, peak-to-peak or rms voltage (fixed or variable voltage)? Budget?
Probably 1 KHz is enoughWelcome to AAC!
by Duane Benson
by Jake Hertz
by Aaron Carman
